DIY: 2005 Volvo XC90 2.5T: ATF, Angle Gear, AOC/RDiff Fluid
2005 Volvo XC90 2.5T: ATF, Angle Gear, AOC/Rear Diff Fluid
Nicodemus0
- Year and Model: 2006 XC90 2.5T AWD
Thanks again to the OP for posting all the detail on this. Bought my '06 XC90 2.5T a year ago, now at 107k, and just finishing getting everything up-to-date based on everyone's guidance here. This week had the three differential fluids and AOC filter changed by my local Volvo independent shop, all with OEM fluids/parts purchased online. In the event it helps others, here are the most up-to-date Volvo part numbers and my costs for everything (YMMV), as many have changed since the original post:
Angle Gear Fluid (#31367237): $26.07/L
AOC/Haldex Fluid (#31367941): $18.98/L
AOC Filter (#30787687): $22.45
Rear Differential Fluid (#31367238): $17.73/L
For what it's worth, labor charge was $80.
- Has thanked: 17 times
- Been thanked: 35 times
Thanks for the write up... I have a AWD '07 S40 manual transmission.
This stuff seems the same with my car and the info here helps a ton.
To the last poster: Nicodemus0 I noticed you have an Angle Gear Fluid listed.
I did not have that in my basket at FCP so I added it. The Volvo regular manual transmission fluid (#31280771)- 2 liters worth was in there instead. Can this not be used for the angle gear too, or is the one you listed recommended (#31367237) which FCP lists now as part #31259380? I'm a bit confused as to where the angle gear is- is it up front and is still separate from the transmission that is accessed near the front left axle shaft spindle? Remember that I'm talking about a manual transmission and you might be talking about an automatic. Thanks for any help on this!!
Turbo_Boss
- Year and Model: 2008 XC90 3.2AWD
- Has thanked: 12 times
- Been thanked: 2 times
So just curious
Is there is a Aftermarket Oil I can use on the AOC System instead of the Volvo one PN 31325136, Volvo sells this for $18/L.
THX
Isaac
THX
Isaac
2008 VOLVO XC90 3.2L AWD
2008 TOYOTA Prado 2.7L 4x4
2009 VW Jetta 2.0
2009 VW Jetta 2.0
camshaft190
- Year and Model: 2006 XC90 2.5t
Long time lurker, first time poster here...
Thanks for this writeup, great pics and detail!
One remaining question I have is the fill amounts for each item, Angle Gear, AOC and rear differential. In the event someone has a weep/leak they will not want to replace exactly what was removed. I have read other notes on this and it appears that you should be filling to the hole then remove a certain value, for example .1l ( 100ml).
One post mentioned that 160ml should be removed from angle gear, then 100ml each for AOC and rear diff.
Does anyone know the precise amounts that should be withdrawn once the level is even with the fill hole? I am a bit lost on what subscription I would need to VIDA to get this info (the only info I need at the moment). Any insight would be appreciated. I am not sure if there are different specs for each year but I am looking for the fill values (not capacity) on a 2006 XC90 2.5t awd.
I apologize if I missed it somewhere but I cannot find these values for the life of me.
Thanks in advance
Thanks in advance
marmotteNZ
- Year and Model: xc90 2004 awd 2.5T
+1 for camshaft quesiton above!
Hi cn90
Thank you so much for this great post!!
I've recently bought a 2004 XC90 T6 AWD @79K miles - and suspect PO did the same - didn't service these or changed fluids. Which might explain why the AT failed in 2016 and the PO had to spend a fortune to rebuild the AT!
I'm now contemplating on the jobs you've posted above!
Hope you don't mind me asking a few silly questions (I'm almost a complete newbie):
1) Am I right to understand from the diagram above - that the AT and Front Diff share the same fluids (ATF) - which is why you didn't specifically document changing Front Diff fluid? If so, I won't bother with Front Diff fluid - as the AT was rebuilt only a couple of years ago and the fluid colour is very clean.
2) After you drained the AT, did you change the green clips on both upper and lower lines (I'd assume so - but since you didn't explicitly mention changing upper line's clip - thought I'd ask to clarify).
3) After you changed the AOC filter - did you encounter any error codes? Can't remember where but I recall reading on other forums folks who serviced AWD filter (I'd assume AWD filter is the same as AOC filter??) had funny codes that were tricky to erase... I do have a VIDA but just want to find out if this is a possibility.
4) Last, how far is the Rear Diff / AOC fluid bolts from the AOC filter? I've managed to find the AOC filter by chance - but not the drain bolts (admittedly I didn't look hard enough for them)
Thank you so much in advance!
Namo Amituofo
Namo Amituofo
Hi, not pretending to know better than you - as I've yet to do these jobs myself for the 1st time - but if you search on Youtube for a video called 'servicing haldex AWD on a volvo' by a guy called 'volvosweden' - he went through the processing of driving the car for a while and removed some fluid - after filling to the brim of the fill hole.camshaft190 wrote: 11 Oct 2016, 12:08 Long time lurker, first time poster here...
Thanks in advance
Cheers
Namo Amituofo
Worth noting that I have done the angle gear and rear differential on my 2013 XC90 3.2 AWD.
The angle gear on this model looks quite a bit different than the one shown in the pic, but it's actually even easier to get to. Just a vanilla simple 3/8 ratchet with the correct socket will remove the plug.
- 746 Views
Last post by 850 LPT
- 396 Views
Last post by RescuerRam3
- 1490 Views
Last post by darrylrobert
- 22 Replies
- 9463 Views
Last post by doublebug
- 1511 Views
Last post by Turbo_Boss
