1995 Volvo 940 Too Much Coolant? Issues?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
difflock54
Year and Model: V40 Nordic 2002
Has thanked: 7 times
Been thanked: 2 times
Re: 1995 Volvo 940 Too Much Coolant? Issues?
Post by difflock54 »
You need to check the radiator spigot to which the radiator hose is attached to for cracks.
If cracks exist the coolant cannot expand and push coolant back to the coolant reservoir as the system is unsealed.
As you have witnessed a leak at the spigot/hose connection that is your starting point to reseal the coolant system.
difflock54
Volvo temperature gauges are not super sensitive therefore when the needle moves from the normal range to the RED the motor is very hot and damage can occur quickly.
Las940
Year and Model: 1995 Volvo 940 Sedan
Post by Las940 »
difflock54 wrote:You need to check the radiator spigot to which the radiator hose is attached to for cracks.
Thank you for the clear explanation. I noticed that if I squeeze the lower radiator hose, I can hear air escaping from the upper radiator hose where it meets the radiator. Note that the clamp is tight to secure the connection. Sounds like the radiator spigot has a crack that is allowing coolant/air to escape, thus, eliminating the efficiency of the cooling system vacuum.
My new question is: Is it possible to repair this type of crack, or is it recommended that I replace the radiator? I know this varies on a case-by-case basis, but what is recommended in general?
Thanks again.
difflock54
Usually needs a new radiator.
Repairs sometimes fix it but it could recur again later anyway.
Care needs to be taken whenever manipulating hoses onto the spigots to avoid damage to the radiator.
Especially the plastic ones, they can be quite brittle.
I don't recommend any radiator stop leak products for this. Do it properly
