Is there such thing as too much coolant pressure. I have a very slow leak from my Coolant Expansion Tank (reservoir), I replaced the rubber line but I see coolant coming out of the rubber hose (the one connected to the tank) ever so slowly. I see that the nipple has a steel insert so I'm not sure how this is possible.
Should I buy a new coolant tank or is there somehow too much pressure due to something else at Fault. THe coolant has been changed and is nice and clean.
1998 T5 - Too much Coolant Pressure
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Sure it isn't just a hose clamp issue? Have you checked, re-torqued the hose clamp?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Yes I've tightened it down and also tried a different clamp.
Also to add: Thermostat and ECT was changed a couple months ago. All cylinders have good compression, I don't see any fluid coming out of Rad cap, just the nipple on the reservoir.
Does the cap normally vent to reduce pressure and maybe this cap isn't working right? It is a Green Cap
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- E Showell
Cap should vent to reduce pressure. The caps do go bad and/or there was a bad bunch of caps out there a while ago. I'd try replacing the cap and see if things improve.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
I have had to replace a '99 reservoir as well at about 150K miles.
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 1498 times
- Been thanked: 3810 times
135K miles on my 1999 reservoir - replaced.
mecheng
Ok thanks, I'll try a cap from the 850 first.
Yes indeed, I try to support Volvo when I can, oem parts are good for the money
- 18 Replies
- 10145 Views
Last post by erikv11
- 964 Views
Last post by Darkskies65
