98 V70XC AC Hose Weeping Oil
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Re: 98 V70XC AC Hose Weeping Oil
Post by mecheng »
to check the weep hole, you need to remove the plastic shroud, one bolt on each side. Typically the oil leak is from the turbo area, I have a very small leak but I don't notice it in the dipstick. The volvo dealer said all Volvo turbo's leak a bit of oil, don't worry about it. Your A/C lines look okay, if your a/c works they are not leaking
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
jmana
Year and Model: 04 xc90
Post by jmana »
It's got 188,000 miles. Yeah the AC works fine. I don't know about the PCV, I haven't checked it since I bought it, I guess I should take a look at that this weekend and see if it needs a going over.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
jmana wrote:It's got 188,000 miles. ...the PCV, I haven't checked it since I bought it...
Boy, is it well overdue! Need to be serviced now or else the expense will become highly cumulative.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
jmana
Post by jmana »
Well I just bought it like 6 months ago, I definitely didn't let it go 188,000 miles without checking it :shock:
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Clean up the lines to the oil cooler at the radiator. See if oil returns - it is not at all uncommon for them to leak at the crimps.
And yes, investigate that PCV system! Though it wouldn't spray oil there.
'98 S70 T5
2016 Chevy Cruze Premier
