As you might guess I have a nasty boy to fix
97 850 NA SAS woes
- Has thanked: 1505 times
- Been thanked: 3818 times
Re: P80 SAs 3517907 exhaust manifold hardware m16 thread
I got this puppy apart with an overnight soak in gas and motor oil, 1:1, then a 21mm impact and crescent
That coupler piece is not going to be easy to find
It’s M16 on one end, M19 on the other , and the m19 end has a tapered inside to take the swage on the SAS air pipe.
Be nice to that unicorn part..it says it is available at Volvo web store but .....
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Is that a metal shaving in the threads of the fitting?
Nice gorp of antiseize
Added pictures above
850oldschool
There are a few listings on ebay for SS compression fittings in M16x1.0 and M16x1.5 for 12MM tubing.
M16 thread into the exhaust manifold ‘
M19 thread with an internal taper for swage on the other end
850oldschool
Is there a swaged flange like on the high pressure power steering hose(where the o-ring fits), in addition to the compression sleeve?
I’ll shoot an internal picture this morning.
It took me just as long to free the taper from the swage as it took to crack the male M16. To male M19 coupler off the union nut on the air pipe.
- 453 Views
Last post by cn90
- 671 Views
Last post by wjhandy850
