s70gltnewbie wrote: 12 Feb 2020, 20:27 DIRECT PATH OF EXHAUST PORTS TO DRIVE THE TURBO IS MUCH MORE EFFICIENT THAN THE LPT OR EVEN OLDER T-5 TYPE.
Will an R exhaust manifold bolt up to a glt with no problems?
whats to be gained from R manifold on s70 T5?
s70gltnewbie
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Yes It will also bolt up to the GLT. Your LPT engine uses the same exhaust port and turbo mounting configuration as the later "R" manifold, which became the 2.5L turbo manifold. It uses a different runner design, but mounts the same. Some say the power gains aren't significant on otherwise stock setups. There is a possibility that it may reduce the incidence of burnt valves due to improved scavenging, and it sounds a little different than the earlier manifolds. Look for one in any 2.5T equipped S60, V70, XC70, XC90 .s70gltnewbie wrote: 12 Feb 2020, 20:27 DIRECT PATH OF EXHAUST PORTS TO DRIVE THE TURBO IS MUCH MORE EFFICIENT THAN THE LPT OR EVEN OLDER T-5 TYPE.
Will an R exhaust manifold bolt up to a got with no problems?
Current Volvos:
- 18 Replies
- 45746 Views
Last post by 98v70dad
- 3822 Views
- 17 Replies
- 3013 Views
- 750 Views
Last post by justin.schnee
- 736 Views
Last post by aero1310
