That IS the underside of a 1995 850 console. I know the SRS computer. I've replaced it in my '93 850 GLT, and am soon to be doing the same on the '95 T-5R.
That SRS unit is from '93-'95 850.
They have the red tag. They were adding random foam pieces in those years to stop rattles in the console. I would not worry about it. You can also see a what appears to be either a glue spot, or a coffee spill on the SRS unit.
The manual seat on my '93 also had that "tilt" lever. I have since replaced it with a powered seat from a '96.
Move on. If it fell out from under the console, it was no longer doing much.
Looks like you made a nickel while you were in there.
1995 850T Random Piece of Foam Found
Ben850
- Been thanked: 7 times
Re: 1995 850T Random Piece of Foam Found
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Ben850
I found a Buck 2.50 when I pulled the wagon seats!polskamafia mjl wrote:My 850 only takes money, it never gives any back.Ben850 wrote:
- Has thanked: 292 times
- Been thanked: 765 times
Foam, what foam??
I only noticed the nickel!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Thanks a bunch.Ben850 wrote:They were adding random foam pieces in those years to stop rattles in the console. I would not worry about it. You can also see a what appears to be either a glue spot, or a coffee spill on the SRS unit.
As for the nickel, I was also replacing the lightbulbs in the ECC unit, and found that a nickel, which happened to be in the car's center console for god knows how long, did the trick in removing the radio piece.
Again, thanks a bunch Ben850 for the information. I'll make sure to pass it along if I ever read or hear someone else who had the same thing happen.
