I just finished getting the 1/0 cables hooked up.
The voltage at the battery was exactly the same as the alternator output...14.00 !!!
I turned every electric option on high and the voltage was still the same between the
battery and alternator (13.5). It was late so I didn't test drive it but it looks like the voltage
drop is gone.
Where does the black vacuum line that is on the back of the air box go to ?
It came off and I didn't see where it attaches. Didn't spend a lot of time looking.
Thanks for all your input.
1999 V70 Alternator output
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Hurray!
There are two vacuum line connections on the back of the airbox.
Upper one should go to the back of the vacuum tree near the throttle body.
Lower one loops around to the front of the airbox; there is a connection there at the bottom front of it.
'98 S70 T5
2016 Chevy Cruze Premier
DML
- Year and Model: 1999 V70 non turbo
I drove the V70 to work today and was in and out several times on calls and it ran fine.
I was waiting for the light to change and thought well I guess the cables were the problem.
The light changed and I went through the intersection and the car died just like before.
Let it sit about 20 mins and it cranked but was sputtering a bit and I didn't go far at all and it died
again. I though this is acting like its out of gas. So at lunch I called the wife to pick me up and I got
my trusty 1990 Jetta and drove to Carquest and got a fuel pump relay. Pulled the old one and checked
for voltage on terminals 15 and 87 and it was good. Next I put my homemade fuel pump relay switch
in and ran the pump so I started it up and let run a bit. Put the new relay in and went for drive and
so far so good. I'll update again after some drive time.
1999 V70
precopster
- Year and Model: Lots
- Been thanked: 128 times
You're on the right track with the fuel relay jumper. Just be sure you replace it with a relay once you've done the testing.
Keep us up to date and let us know if we can mark this one Solved
- 1626 Views
Last post by Kraig
- 15 Replies
- 2727 Views
Last post by thefisch
- 606 Views
Last post by Herb Goltz
- 1349 Views
Last post by DeeSi
- 18 Replies
- 4211 Views
Last post by skloon
