1998 volvo s70 t5m codes galore
precopster
- Year and Model: Lots
- Been thanked: 128 times
Re: 1998 volvo s70 t5m codes galore
The red hose goes to the vacuum tree on the inrake manifold just beneath the IAC. It's a 4mm line.
huzzsaba
- Year and Model: 2004 volvo xc90 2.5t
UPDATE: Got everything put back and started the car and still getting code P0102 for the Maf sensor. I checked all the vacuum hoses, and connectors and everything is plugged in and secure. Is it possible that Maf Sensor is bad?
On a positive note, there is no smoke coming out of the dipstick and the stumble on idle is gone. Any other ideas besides replacing the MAF sensor?
Thanks
Thanks
2004 Volvo xc90 2.5t
1998 Volvo s70 T5M
1998 Volvo s70 T5M
huzzsaba
UPDATE> found a used 2 year old Maf and installed it and no more codes. I drove it around the block for a bit and it seems to be a little slow until the turbo kicks in, but that could be because it hasn't been driven in a while and one of my brakes is dragging.
1998 Volvo s70 T5M
1998 Volvo s70 T5M
- Year and Model: Many Volvos
- Been thanked: 75 times
If the old MAF was not accurate the adaptives are messed up and it will take a while for the ECU to relearn its new center trim points. You can hasten the relearing a bit by removing a battery cable for 30 seconds or so (you will need to have your radio code). Even after a hard reset the mileage and performance will not be optimum for the first tank of gas or so.
- 1514 Views
Last post by mt98t5
- 603 Views
Last post by mathy221984
