1998 Volvo C70 Overheating and fog on windshield
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Should be expansion tank CAP.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Volvich
Year and Model: 1998 Volvo C70 Coupe
Post by Volvich »
I appreciate your response!
The expansion tank is only two years old, from dealer. Cap is aftermarket but a good quality.
There's no leaks, bubbles or hissing at all... whats the reason you those might be bad?
E Showell
Post by E Showell »
Boiling coolant. It is almost always the cap, especially if aftermarket.
'95 855 auto (sold)
E Showell
Post by E Showell »
Tank is likely fine. My earlier post was a typo. It should have read cap, not tank.
'95 855 auto (sold)
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Just bypass it and drive till the core comes in. Simple 10 minute thing.
Also you should NEVER remove that cap with the car running it motor warm/hot. And please, stop running the car with a known coolant issue. It will only end badly. I call it coolant roulette.
rspi
Post by rspi »
Bypass video:
Replacement video:
Volvich
Post by Volvich »
As I stated in my earlier post I've bypassed the heater core. The thing is that I'm getting the same problem as I was getting before bypassing except there's no white smoke coming out of air vents (since I've bypassed that). Years ago I had a bad coolant tank, and bad cap at different times, and yes the coolant was boiling, but the temp gauge was always at 3 o'clock position. Now it goes up. I suspect the problem is elsewhere...?
E Showell
Post by E Showell »
Could be bad ECT (engine cpolsnt temperature sensor).
'95 855 auto (sold)
Ben850
Been thanked: 7 times
Post by Ben850 »
Volvich wrote:As I stated in my earlier post I've bypassed the heater core. The thing is that I'm getting the same problem as I was getting before bypassing except there's no white smoke coming out of air vents (since I've bypassed that). Years ago I had a bad coolant tank, and bad cap at different times, and yes the coolant was boiling, but the temp gauge was always at 3 o'clock position. Now it goes up. I suspect the problem is elsewhere...?
Is your C70 the LPT? There are still two small turbo coolant lines that might leak.
One is at the turbo underneath, the other would be behind the #1 cylinder near the lower expansion tank coolant tube. They all connect to the external metal coolant manifold on the backside of the engine.
Search for drops of coolant in those areas. You simply have a leak. Look for discolored oil, indicating a gasket, or block breach.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Volvich
Post by Volvich »
To Ben850: I'm pretty sure there are no leaks, since coolant level in expansion tank is steady.
So I changed the heater core, flushed the coolant, put new stuff.
It looks like the coolant doesn't flow through the radiator. I monitored the coolant temp on OBD II scanner (Torque app). At 102 Celsius fan came on but the temp went up regardless. At about 120 C coolant started leaking at firewall connector. But here's the thing: radiator upper and lower hoses were cold. Not even slightly warm. Does that mean the thermostat has failed?
I visually checked the water pump. No leaks there.
