thank's. Tomorrow i try to reset all code and read the mileage from ECU.
Please where i found the free service manual?
Bye
How to read your actual miles from the ECU
How to Read Actual Miles from the ECU
- Has thanked: 17 times
- Been thanked: 35 times
That is correct, you must read the lights blinking.
If you take the odometer out you can set it to match the correct mileage, but I would read the mileage a few times first to make sure it is correct.
There is a good write-up on how to advance the mileage on the odometer with the use a pencil and drill.
fredstock99
- Year and Model: 1993 850 GLT
I got a 1993 850 GLT, and I just tried this and here is what I got... Just wondering what it means.
After pressing 5 times, and entering code 1-1-1 according to step 3,4 of original post, i get this response "10-3-1" ... After entering code 1-1-2, i get "1-10-6." if i understand this correct, the 6 digits of my mileage read as "1,10,6,10,3,1". Is this correct, and what does that mean? My odometer was broken for about 4 months until i found a used instrument panel and just swapped the whole thing.
1993 850 20 Valve 5 cyl : had 190k miles when i joined this forum : nor cal - so cal - long island. Now i live in NYC, its got 259k miles, and sadly, the only car I've ever owned is going to be scrapped. RIP Black Volvo. You will never be forgotten.
- Year and Model: Many Volvos
- Been thanked: 76 times
It means that the panel is reporting 106,031 miles. However, since you changed the instrument panel, that is the mileage associated with the replacement instrument panel, not the car. If you want the true mileage of the car, less the miles since the panel change, I think you need to put the old panel back in and read the mileage again from Socket A-7.I got a 1993 850 GLT, and I just tried this and here is what I got... Just wondering what it means.
fredstock99
Thanks Lee. I switched back to the original instrument panel and read 189k miles. So i read that really nice odometer fix on this site, and took care of that, plus rolled my gauge forward to account for mileage on the other ins. panel. Now i get to watch my car hit 200k sometime this summer
. Thanks again.
luketrash
- Year and Model:
- Been thanked: 2 times
Thanks for the heads up about the mileages being attached to the particular gauge cluster installed in the car. I had thought it was stored in the ECU.
'94 Gunmetal Gray 855 2.4L 100% stock. This is Volvo #7.
volvo 850 t5r
ok,i tried it out!
first step 1-1-1
8 red blinks
7 red blinks
10 red blinks
second step 1-1-2
3 red blinks
5 red blinks
5 red blinks
so if im not wrong this should be 355870km or miles?my car is italian and my speed o meter is in km!
wouldnt be bad...that bas*ard that sold it to me said it had 136000km on the clock
ok,i tried it out!
first step 1-1-1
8 red blinks
7 red blinks
10 red blinks
second step 1-1-2
3 red blinks
5 red blinks
5 red blinks
Volvo 850 1995 T5-R 2Litre 210HP "420.000KM"
Volvo V70 2002 D5 "315.000KM"
Volvo V70 2003 R "144.000KM" (Coming Soon)
I've tried this twice and it works well. I used it to put the correct mileage back on my odometer after I fixed the broken gear.
NOTE! The instructions say to turn the key on. This means start the car, don't just turn the key to the on position! Mine would not work with the key in the on position, I had to actually start the car.
Wes
Wes
oh!!i didnt start the car....wondering...ill give it another try with the car on!
thanks for the hint
thanks for the hint
- 3134 Views
Last post by Rucho26
- 1993 Views
Last post by coflynn
- 23 Replies
- 3963 Views
- 1685 Views
Last post by 850_GLT_Owner
- 4002 Views
Last post by jonesg
