2000 V70XC SE - First Time DIY Oil Change on Volvo
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
sea warrior wrote:Question: is it OK to post them in this same thread, or is it protocol to start a new thread for each separate issue? Appreciate your thoughts.
You are fine, this is a continuation of the same topic.
If you were to have a MAF sensor problem or something else that is not related to an oil change a new topic would be appropriate.
Has thanked: 1609 times
Been thanked: 4064 times
sea warrior wrote:Update:
Well, whoever was changing the oil before seems to have not used the plug bolt- It is stuck on! I pulled as hard as I could, and the thing wouldn't budge- started to deform slightly, so I stopped. The plug bolt also just looks too clean to have been used (see photo) so I would guess they must have been doing it by fluid extraction.
So it seems like I need to get into a shop where they can get this bolt loose with an impact wrench. Unless anyone has any other ideas, I will be headed there in the morning...
Thank you for all your responses, by the way. Really appreciate it.
Have some other pictures, by the way, of some messy areas down there I noticed.
Question: is it OK to post them in this same thread, or is it protocol to start a new thread for each seperate issue? Appreciate your thoughts.
Try a six point 17mm socket on that with an extender, and pull nice and slowly. You might want to have a replacement on hand if you deformed it significantly, but it really doesn't need to be that tight.
I think the oil drain plug torque is 38Nm ..... roughly 24 FT lbs...please confirm that with search.
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
Get a new crush washer for that drain bolt too. Might as well replace the bolt too, eeuroparts has a magnetic one for 2.50. People always overnighter it and dedestroy the crush washer in the process. I always torque mine down just right so I don't replace the crush washer everytime.
If you buy the cheap version of the oil filter housing wrench take it to any garage and have them spot weld the nut in place. Otherwise it will break off the first time you use it.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Put the 17mm box wrench on, use a floor jack, one hand making sure the wrench is in place, the other hand raising the floor jack.
I re-use my washer.
Post by cn90 »
Make sure you turn it in CCW direction when viewing directly at the bolt head.
sea warrior
Year and Model: V70 XC SE 2000
Post by sea warrior »
Great idea about the floor jack! My only worry is if the bolt head shears off, then what? Oil everywhere? or just a stuck plug needing an extraction/rethreading. Ideas?
2000 V70 XC SE, @103,000 mi. when purchased this year, USA
dosbricks
Been thanked: 4 times
Post by dosbricks »
The corners would likely round before the head would shear off. cn90 has the idea--a six-point box-end wrench is the tool to apply torque within the same plane as the bolt head. Slow and easy does it with the jack. A bottle jack might be preferable to a roll around floor jack because the latter pulls toward itself when raised and you would have to watch it to make sure it didn't pull your wrench cockeyed. Good luck!
Redneck
Year and Model: Volvo 854 1996 GLT
Has thanked: 10 times
Post by Redneck »
I have nice ramps from Autozone. They are cheap and reliable.
Rbaratt
Year and Model: 850,S70,C70
Post by Rbaratt »
I chock the rear wheels ($7 from Harbor Freight), jack one side of the vehicle up, lower that side onto a ramp with a jack stand under the subframe, then repeat for the other side. Later I remove the jack stands and chocks and drive down the ramps. I do not like driving up the ramps, just my preference.
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I never drive up on ramps without a helper to tell me when I've hit the flats and to keep me from driving over them. So far, no problems, but I wouldn't be anxious to try driving up on ramps alone.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
