1998 V70XC stalled while idling
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Usually if you have a stall, with NO CEL, you have a fuel pressure related problem, I.e. fuel pump relay or pump failing.
Has thanked: 1609 times
Been thanked: 4064 times
I would follow the fuel pump relay route first, Dirk. You usually get some funky electrical warnings with the bad ignition switch, not just stalling.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Thanks guys,
I have to do some research on here regarding the fuel pump relay. But I'm thinking if this is a random occurance maybe I should just replace it. The last thing I need is to be stranded somewhere because of it failing permanently.
I know there is the temp paperclip fix too, but I have to find out how to do it and maybe put one in the glove box just in case.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Ben850
Been thanked: 7 times
Post by Ben850 »
850 LPT wrote:Thanks guys,
The #103 relay can go bad. Does your fuel gauge still function on the '98? The saddle tank fuel pickups can also be an issue.
I have been doing some research on the AWD '98s. Have also taken a complete fuel pump from the scrap yard to find fault.
I had noticed a burn mark on the float contact indication at approximately 1/2 tank. I am not aware of that causing a fuel depravation, but a false, or negative reading quite possible.
In my case probable.
Weather permitting I will dig deeper.
I feel fortunate to have two functioning vehicles. I did want the AWD for the winter, but am fine with the sleeper wagon on snow tires.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Search for the thread jumping 15 and 87 on the fuel relay SOCKET.
Leave the jumper wire there for a few days as a temp fix. If the problem goes away then the relay is bad.
The fix is in the forum.
rspi
Post by rspi »
If you can afford it, replace the relay every 10 years and never worry any more, about the relay anyway. Many of us carry a spare in the glove box.
Post by cn90 »
I have mixed felling about fuel relay, which may last 3 years or 20 years. It is one of those unpredictable electronic parts, namely the capacitors inside the relay.
The most inexpensive and bullet-proof way to handle this issue is a jumper wire, which only costs some $2 at local autoparts store. Keep some Torx keys and this jumper wire in the glove box and you are ready for this emergency...simply jump 15 and 87 and you can go home.
Detail below:
https://www.matthewsvolvosite.com/forums ... =1&t=52252
Photo is here:
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
The jumper works for sure but there are some minor safety concerns to running a jumper wire. Spare relay is the way to go for me, as soon as you have to use it (if ever), then get another spare for the glove box.
850 LPT
Post by 850 LPT »
I think I'll just order a new one. FCP has it for $55, which is not that bad for a little piece of mind. Chances are I'll never have to buy another one.
RigsPGT
Year and Model: Red 99 S70 T5,
Been thanked: 2 times
Post by RigsPGT »
If i was you, i would buy a good used OEM mass air flow sensor and store it in the glove box.
I had similar issue although at first the car stalled on me without throwing a code right before a 1200 mile trip. I blamed bad fuel but later on the car was jerking at highway speeds and stalling on exits. After 200 miles of driving (playing Russian roulette) finally the car threw me a bone (cel) for bad maf (P0103)
Disconnected the maf, car came back to normal a
nd drove from FL to NJ and back to FL just like that. I even got a steady 26mpg drivin 75-85mph for the whole trip.
Now i even bought a spare sensor just in case i experience the same situation again.
As for the other lights, as long as they are off at the moment i wouldn't sweat it.
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
