2001 Volvo S80 engine system service required
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
I think it was TCU codes that it couldn't access.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
naperboiler
Year and Model: S80 T6 1999
Post by naperboiler »
I had the same error on a 99 S80 T6. The problem was the brake pedal position sensor. When you have the error present, your cruise control may not work. I removed mine, disassembled it and re-soldered the broken solder joints. Make sure you bring the vacuum assist to atmospheric pressure before you pull the sensor or you are likely to lose the 0-ring that seals the sensor.
