2000 S70 T5 Stalled on freeway
Has thanked: 1610 times
Been thanked: 4071 times
That's a tough one to answer, I'm afraid. Maybe do a compression test when you get it back.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
clifford06 wrote:Greetings. I will get a chance to look at my situation tomorrow, trying to beat bad weather. My question is " If the headgasket is not blown, and my leak is due to busted hose. What caused my power loss.?" Thankfully I haven't had to deal with bad Hgaskets before. Thoughts and opinions respected.
The two may just have converge at the same time.
As MVS Maverick often says, "do not over analyze".
Heating and cooling is mother of all systems.
Replace the coolant hoses, and restore the system.
How is the reservoir tank itself?
Take it from there.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Loss of power... sounds like the car jumped time. Coolant on the passenger side??? Sounds like the water pump failed and caused the car to jump time.
Pull the cover and see what it looks like there. Do you have any idea what brand water pump was installed?
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
rspi wrote: Sounds like the water pump failed and caused the car to jump time.
I thought the exact same thing, because that is what happened on my XC last year. But how are the odds that a fairly new water pump (20k) fails? .
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
rspi
Post by rspi »
That would depend on the pump brand, coolant type, and the tension set on the tensioner by the installer.
xHeart
Post by xHeart »
HEPU failed closed to 10K. Installed at Indy during TB job.
Thread here https://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=50545
rspi
Post by rspi »
I seen a post of FB recently that had the pulley off of the shaft on a Hepu pump (yes the engine was toast). It appears that the pump had about 50,000 miles on it. Time to stay clear of Hepu pumps.
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
Greetings. The TB kit is a Gates TCK WP331 ordered from Amazon. Installed by a local Indy . Could not inspect today due to heavy rain soon to turn to sleet and ice.
clifford06
If TB skipped, am I looking at a head job due to possible bent valves ?
Yes, if it skipped more than a two teeth
