2003 Volvo V70 High mount brake light
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Been there myself. It's a pain when you pull into the gas station and the filler door won't open because some fuse on the REM keeps blowing every time you lock the doors.
https://www.matthewsvolvosite.com/forums ... =9&t=47882
Googs1080
Year and Model: V70 2003
Post by Googs1080 »
ugh celebrated too soon. Anyone have insight why the high mount brake light would be dim? I check voltage and it was fluctuating between 7.4 upto 9. Once it hit 11.1 volts. You can see the lights flickering. I thought LED were either on or off. I know I spliced the broken wires but I measured and got nearly the same voltage at the splices as I did at the light socket. is there something feeding that could be sending dirty waivering signals? The shop failed my inspector today cause the light didn't come on. I think they tested it with the car off. It is my understanding this light only comes on if the car is on
