2000 s70 t5 Compatable engines
Has thanked: 1502 times
Been thanked: 3817 times
Re: 2000 s70 t5 Compatable engines
I think there are three engines in play here
2.4 NA
2.3 LPT
2.3HPT
If your T5 is like mine it has the 2.3HPT
I would stick to that engine if you don't want a major project.
On edit...I just did a quick scan of resources And these models were changing over the 99 00 01 years.
Search for the specific year manuals online, and then go back to the technical section to get the exact engine code (Bxxxxx) to match
Sorry I can't do this from Ipad on the NYC subway.... :-)
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The 2.4NA from 99 has no CVVT and the 2.4NA from 2000 has CVVT on the opposite side to your exhaust CVVT on your T5.
Stick with the other two turbo choices for ease of fitment.
The 2000 and 2001 MY engines were the same and have solid lifters instead of hydrualic. You can tell which you have by the presence of multiple torx fasteners near the spark plug holes on the solid lifter versions.
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
So only use 2.3HPT / LPT or 2.4 LPT correct ? Your help is appreciated.
precopster
Either of the turbos is fine as long as 99 or preferably 2000 MY so CVVT won't present challenges.
clifford06
Thanks. I'll use my injectors and intake / exhaust manifolds.
clifford06
Located a 2.3 HPT from a 2000 C70. Wrecked front end. Any tips on checking engine condition due to not being able to start.?
You should be able to do a compression test if you can reach the electrical connections on the starter.
Look at the level of sludge in the crankcase to get a sense of how it was maintained.
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
+1, def check compression. Similarly, get a flashlight and peer in through the oil filler cap. How do the cams look? You can't see a whole lot this way but better than not looking at all. Sludge or a lot of rust would be bad signs, better would be shiny metal. Best would be if you can see it in the car and get a general idea about maintenance habits.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
clifford06
Greetings. Thanks guys. I'll follow the steps in RSPI's video and keep y'all updated. Seller / recycler invited me to inspect engine before he will pull it.
clifford06
Would the head from a 2001 C70 turbo engine fit my car ? Erie has one and says it will work. There several local. I need to make a decision on this situation soon. Thanks
