Misha, I have done this to bleed the system.
My question remains... How do I test to see that the steering U joint is the issue NOT the rack?
Need steering rack recommendations
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Ok,just wanted to be sure because a lot of people don't know how to properly bleed steering system.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- matt122s
- Year and Model: '98 V70R
hi PresseR, you have to jack up the front of the car so the steering gear is not under load. Disconnect the u-joint/coupling and check it for binding. It should be loose to firm, if it's tight or binding it's junk. They do go bad, not too hard to change.
- matt122s
hi PresseR, I was curious how you made out with the stiff steering issue. I saw this link in the repair database and thought it might help.www.matthewsvolvosite.com/forums/viewto ... ?t=21537&p...
I hope it helps
I hope it helps
- 242 Views
Last post by pfmet
- 1266 Views
- 30 Replies
- 27313 Views
- 1830 Views
Last post by Shift727
- 15 Replies
- 7641 Views
Last post by jtbgonesailing1
