1998 s70 Car ramps
JRev
Year and Model: S70 20V 2.5 1998
Post by JRev »
cn90 wrote:Steel ramps are a pain to use.
Wood ramps are way better, info below...
DIY: 98 V70 Engine Oil Change (& ATF Change): the Easy Way!
https://www.matthewsvolvosite.com/forums ... hp?t=42989
Great write up and these ramps (steel) do look a right pain in the arse! and thats even before attempting to use them, will have a look at getting wood ramps.
JRev
Post by JRev »
In the end I purchased these (5 ton rated (total).):
And this jack
http://www.amazon.co.uk/gp/product/B00H ... ge_o00_s00
And also have axle stands for added protection from being squashed while under car and steel wheel chocks.
JRev
Post by JRev »
So today I done the oil/filter change with the new ramps/jack and this was the setup, jacked up at the middle of the front subframe point and lowered slowly onto the ramps (while keeping the jack in place), nice safe way for anyone to do an oil change on these cars.
difflock54
Year and Model: V40 Nordic 2002
Has thanked: 7 times
Been thanked: 2 times
Post by difflock54 »
My only comment regarding your ramp purchase is related to the length of the level landing points.
They do not look particularly long so chocking the rear wheels is a must I think.
What height above paving is the uppermost landing point for the wheels?
Has thanked: 1610 times
Been thanked: 4065 times
Driving onto Ramps is easier than jacking. If you drive over them it's embarrassing but no damage, and you will learn by doing.
JRev
Post by JRev »
difflock54 wrote:My only comment regarding your ramp purchase is related to the length of the level landing points.
I did have steel wheel chocks on the rear but the chances of the handbrake snapping, wheel chocks failing and ramps cracking are the same as me winning the lottery twice so if I died while under my current setup then I would have deserved it!......Yet these ramps are 5 ton rated and designed for caravans to level out so while I agree they look quite short, in reality they are perfect.
JRev
Post by JRev »
abscate wrote:Driving onto Ramps is easier than jacking. If you drive over them it's embarrassing but no damage, and you will learn by doing.
But then I couldn't have tested out my new jack :P
You jack it up to get the ramps stuck underneath....
JRev
Post by JRev »
abscate wrote:You jack it up to get the ramps stuck underneath....
Better that way as saves on fuel and tyre wear from driving up the ramps :D
