If that turns out to be the case then I have a trusted mobile mechanic I can call on and yeah I nearly ordered the seal but managed to get a cap for the same price as dealer was getting rid of stock.JRL wrote:You may need someone else (ie a GOOD mechanic) to do the breather, it's not for the inexperienced and I would guess about 110% that it needs to be done ASAP, not later, but now.
You don't need to test it, if there's any amount of oil up there, it's clogged.
And, you don't replace the complete oil cap, it's just the $3.00 seal you replace.
1998 s70 tape around spark plug cover
I'm going to do this test as mentioned by Shane but JRL after what you said, have been doing some research on google and research suggests even if your car passes this "test" the PCV systen can still be bad so I guess I better start planning for the system to be correctly looked at as I plan on keeping this car long term.
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
You had mentioned that you wanted to start doing your own mechanical work, this has some skill level and I do not know what level you have. If you can have someone with knowledge over to help, by all means, have him present, but try and do as much as possible.
Keep everyone updated.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Yes Shane, I do want to do my own work and I have purchased the tools etc, started doing my own servicing but if I get stuck then the mobile mechanic can help out but each time there is a job to be done, I watch the guide videos a few times (mainly roberts) so not saying I won't attempt the job if needed as I have the time and space, there is no rush.obayha wrote:You had mentioned that you wanted to start doing your own mechanical work, this has some skill level and I do not know what level you have. If you can have someone with knowledge over to help, by all means, have him present, but try and do as much as possible.
Shane
But will keep you updated, and thanks for the info so far!
obayha
This is a good idea. You haven't said where you are located. Maybe someone is willing to help.kahl wrote:Yout may want to post in the "Help a Neighbor" forum. There could be someone in your area to help you learn about your car.
Shane
1998 V70 T5 331,000
That would be great my friend but I don't plan on moving from the UK, yet!obayha wrote:This is a good idea. You haven't said where you are located. Maybe someone is willing to help.kahl wrote:Yout may want to post in the "Help a Neighbor" forum. There could be someone in your area to help you learn about your car.
Shane
I done the two tests and I "passed" , always nice to pass a test but aswell as the previous garage doing a bodge job on the spark plug covers, they also destroyed one of the threads for the 6 bolts by using an air gun as I noticed before one of the bolts would go in at an angle when tightening by hand.
The filler cap seal is fucked, can see that, so once the new cap arrives, I will run the car for a few days and see if any new leaking oil appears and then take it from there.
But just to add, am not going to leave the system, am going to have it serviced and am watching these guides to see if I can tackle it myself one weekend as the car isn't used much at the moment after being a daily drive for the past year and am going to look through any records to see if any mention of the system being serviced by previous owners.
Updating this thread for this suggestion I found from another forum in an old thread, which I'm not suggesting as an alternative but:
When I got a similar problem I read up about dismantling and cleaning the PCV and oil trap system but in the end improved the situation dramatically just by cleaning out the small vacuum hose from the white plastic Y piece to the inlet manifold. It had completely blocked with carbonised oil for its entire length. I think this small hose is quite crucial for creating vacuum in the system and it is vulnerable to clogging.
obayha
That could be a problem also. That plastic piece becomes brittle over time and usually breaks upon remove. Again, I know this How???
The "J" port going into the engine is also a problem place and therefore removal of box is needed.
How do your rear cam seals look? "leaking or dry".
I was told that the car I have now has never had the PCV system done. I have 171,000 on the engine. It passed the glove test and not leaking from anywhere. You could be lucky and the leak was the cap.
I would be glad to come over and help if you pay travel.
Shane
Shane
1998 V70 T5 331,000
- 3060 Views
Last post by Roger_850T
- 1268 Views
- 3898 Views
- 14 Replies
- 4702 Views
Last post by 98v70dad
- 4338 Views
Last post by erikv11
