94 850 Turbo keeps blowing fuel pump relays
Carbon15
Year and Model: 94 850 Turbo
Post by Carbon15 »
The filter was changed with the pump. If I jump pins 1 and 3 the car will run for a few minutes, then the relay blows. Is there a fuel pressure sensor that's maybe telling it to shut down?
93 850 GLT
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Nope....there is no such a thing on a '94.
Like we told you before....relays DON'T just blow themselves out without a reason.There is either a massive load on fuel pump circuit or some kind of short.The only thing which confuses me is why the fuse for fuel pump is not blowing before it blows relay.
Disconnect fuel pump connector in the trunk and turn the key to position II.If relay don't blow itself off,your fuel pump is the culprit.Maybe it's shorted inside.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
misha, check out this post though:
Carbon15 wrote:I hard wired the relay, still got only a few minutes of run time. What tells the relay to shutdown, and does anyone know where that is?
To OP: Is the ECU (or something) cutting out power to the relay circuit? Are the relays you tried getting cooked, or are they all actually fine?
Carbon15
Post by Carbon15 »
That's the weird part. I hot wired one, and inadvertently plugged in one that I though was blown. Car started right up for about the five minutes.
93 850 GLT
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
Carbon15
Post by Carbon15 »
I'll be scanning the wiring next, problem is the car is about 45 minutes drive away in the garage I was working on it in.
93 850 GLT
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
misha
Post by misha »
erikv11 wrote:misha, check out this post though:
Read & responded: :mrgreen:
misha wrote:Immobiliser.
But...it will turn the car off in a 2-3 seconds....not few minutes.
I would replace fuel pump.
Blowing fuel pump relays,turning engine off after a few minutes....the symptoms are pointing to a bad fuel pump.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1611 times
Been thanked: 4075 times
Ok..what does a " blown relay" mean?
Are they on fire?
Not working?
Please clarify
Carbon15
Post by Carbon15 »
The fuel pump shuts down as the relay disconnects.
93 850 GLT
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Post by draser »
So basically the relay opens up. No melted or welded contact or anything. If there's a fuse anywhere in the pump circuit, it's of correct size, and it does not blow, or open, then pump's fine. If you jumper the relay contact does it stay on?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
Post by erikv11 »
Yes, these questions have already been answered more than once in this thread
- yes there is a fuse, it doesn't blow
- if he jumpers the relay, fuel supply still stays on only for a few minutes
