99 V70 Removal of 'dead foot rest" part 9132550
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
Post by obayha »
Thanks for trying. The bottom pin has a plastic part sticking out at 90 degrees and that keeps it from coming out clean. My floor mat covers the foot rest, so until I order something, it will remain as is.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
obayha
Post by obayha »
Did you noticed how bad the area to the left of the rest was? It was all messed up. Well I used what I had to add a little patch. Thought about replacing the entire area, but that rubber bottom goes under the steering wheel.
Has thanked: 1609 times
Been thanked: 4065 times
It looks like it comes DOWN then back. I would have sworn I pushed my 1999 up and then back.
obayha
Post by obayha »
abscate wrote:It looks like it comes DOWN then back. I would have sworn I pushed my 1999 up and then back.
It comes down,then back,then breaks. :)
The new standard procedure for removal.
I would like to know if anyone has removed one without breaking.
Shane
And the broken piece falls into the bowels of the car so it can't be JB welded back.
v-45magna
Year and Model: 99 S70 GLT
Has thanked: 2 times
Post by v-45magna »
I thought that, too. It has that little curve at one end. Probably a good way to remember it is that you push it the opposite direction of the curve.
obayha
Post by obayha »
abscate wrote:And the broken piece falls into the bowels of the car so it can't be JB welded back.
Looks like me and JB are going to put things back together. It's something simple to play with. I need simple.
If you can find a piece of wood dowel to JB weld inside that it will be a lot stronger
obayha
Post by obayha »
Already thinking, Threaded rod, with maybe a washer and nut on the end.
Major weekend project. :lol:
Shane
:D :D :D
Titanium rod best
:D
