On an 2004 check that CEM is dry. Usually it’s the BCM on p2 chassis. Read codes to confirm.
BbA is no longer in business last I checked
2005 S60 "Brake failure stop faely"
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Usually this https://www.fcpeuro.com/products/volvo- ... e-30742306 or this https://www.fcpeuro.com/products/volvo- ... vo-8622064 Can replace both - my failed at around same mileage.cn90 wrote: 19 Apr 2023, 10:37 The 2004 V70 2.5T with some 130K miles just showed this message..."Brake Failure, Stop Safely"...
- I understand this is mostly anti-lick features.
- Car brake work fine on dry road. Have not tested hard braking on wet road yet.
Coming from 1998 V70, we just sent the ABS module to be resoldered, cost was $80 years ago...
Could someone give me an update on this?
- The root causes of this? Is it broken solder joints?
- Any soldering trick, has anyone tried this?
- What does Xemodex (In Toronto) do, is it mostly resoldering?
- Any company in the US? Is BBA-Reman still around?
vtl
It is 99% sensors. On 3 P2s I've had, I replaced 3 of those on brake booster and 2 on brake pedal.cn90 wrote: 20 Apr 2023, 06:17 Thanks for the replies,
I thought this is usually from the BCM and not the sensors as mentioned by vtl?
Read the codes with DiCE/VIDA, we can compare with what I had.
