Tire sizes
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
Post by obayha »
The 15 inch wore out on my '99 so I replaced them with the 16's from my '98, so I hope it will all work out. I understand 16 inch tires cost more, but at this time , they are free and I will worry about cost down the road, as I am keeping both sets.
I am riding so must higher now. :lol:
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Rondo
Year and Model: 2000 S70 GLT/SE
Post by Rondo »
scot850 wrote:The difference is due to the rotor size. Some cars have 280mm rotors (15" rims and up will fit) and some had 302mm (16" and up will fit). The 98 V70Xc we had had 280mm rotors as standard and 15" rims, but you can go larger. Remember the wider the foot print of the tire in snow spreads the load but does not grip as well or cut through the deeper snow. Hence my original reply saying the listed tire size was 195/65/15 for this car v's the 'summer' size of 205/65/15.
The difference in the rotor size is achieved by obviously the larger rotor and a different mounting bracket using the same caliper. Seem to recall you need a longer flexi-hose too.
Is it the same caliper? I accidentally bought the 302mm rotor on my last 70 and the caliper seemed way too small. I don't doubt you at all, just interesting that I could have just switched brackets and kept the bigger brakes.
Nautic Blue '00 S70 GLT/SE, RIP @ 273625 Miles
Black '00 S70 GLT/SE, 141K Miles
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Rondo wrote: Is it the same caliper? I accidentally bought the 302mm rotor on my last 70 and the caliper seemed way too small. I don't doubt you at all, just interesting that I could have just switched brackets and kept the bigger brakes.
280 mm calipers will work on 302mm rotor. Although there are no new or refurbish 302mm brackets available anywhere.
85 GLH, 367 whp
00 Insight, 72 mpg
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
scot850 wrote:(15" rims and up will fit) and some had 302mm (16" and up will fit).
I just wanted to add that you have to be careful, not all 16" rims will clear the 302mm rotors. I know for sure that the 16" Persus wheel for example does not fit (I tried it).
On another note, I now run 195/60/16 Pirelli snows on my XC and it turns out to be a great fit. The tire is theoretically 1.1% smaller than the 205/65/15, but that's no biggie.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
dr1vereye
Year and Model: 1998 v70 xc
Post by dr1vereye »
I found some 205/65/15 winters on steel rims for $300. They are off an early 2000 Ford Taurus.
I attached (factory rims specs picture). It seems the centre bore will be loose. And the stud size????
Would this be a risk?
Tom
dr1vereye
Post by dr1vereye »
I attached (factory rims specs picture). The second vehicle is the Taurus. It seems the centre bore will be loose. And the stud size????
Tom
Has thanked: 2210 times
Been thanked: 1852 times
Looks like the other way around. If the Vehicle 2 is the Taurus, then the wheels won't fit as the hub center is too small. You would need the center bore to be machines out. Also the stud size is less of an issue as again it is smaller, but may cause some wheel wobble if not tightened carefully.
dr1vereye
Post by dr1vereye »
Oops, yes the bore might be too small.
Thanks
Not sure where you are in Canada, but there are usually loads of 15 and 16" winter tires and rims for Volvo on Kijiji this time of year. Here in Calgary there are a fair amount for sale.
dr1vereye
Post by dr1vereye »
Hi Neil, I am close enough to Calgary, I check kijiji everyday. Am I missing something? All the tires are too big or small. Or like the above post, the rims don't fit my model. I don't think I've ever seen a make of car with so many size variations.
Tom
