Seafoam in crankcase? (redux)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
FLXC90 wrote:What I do to introduce seafoam to the manifold by myself is:
Use a cup or something ( I cut a 20oz Coke bottle off)
get a piece of vacuum tube about a foot long, uncap a port on the vacuum tree, connect the line. Plug the end of the line with a golf tee or something to start the car.
pour the Seafoam into the cup, uncork the line and dip into the seafoam, as it bogs, push the line down to seal against the bottom of the cup, or just pinch the hose, as the revs recover, moderate inatake vs bog until its all sucked up, then let it die or shut it off.
Then disconnect the hose and recap your vac tree, wait 10 mins, then rid your neighborhood of mosquitoes :lol:
Almost identical to how I use Seafoam in my Volvo.
Also -> Amazon link
MarcM
Year and Model: 2005 S60 2.5T AWD
Has thanked: 1 time
Been thanked: 3 times
Post by MarcM »
Finally got to oil change after drain plug fiasco. Oil ended up being a deep maroon color.
Filter appears to have been a LuberFiner, but printed # is an R837 instead of P837. Put in a Manner (just like the man said)
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
