If TCM somehow lost adaptations then a harsh 1-2 shift can result. I agree with sw doing nothing to solve this one.
A forced drive cycle Adaptation however may help. This is done by a dealer on a specific drive cycle or you can DIY it if you have a specific (updated) TCM firmware and a Vida/Dice.
If the indie wants a TCM update because the firmware is so old you can't enter into an adaptation cycle then you WILL need an update.
Software Update
precopster
- Year and Model: Lots
- Been thanked: 128 times
- phils94850
- Year and Model: 2009 s60 turbo
thats the issues I'm having with mine is shift flares between 1 and 2 shift after it warms up. The fluid is pretty dark so I'm planning on drain and refill, then add some seafoam transtune, then drain and refill again. I also plan on getting the sw update and doing the adaptive procedure. I'm hoping it will solve the issue.
1996 Platinum Edition
For those model years, I'd be a little careful about paying someone simply to “update all the software.” These aren't like modern cars where you routinely download a bunch of ECU updates yourself.
The first thing I'd ask the shop is exactly which control module/software update they believe is required, and why. If the cars are running normally and there isn't a specific Volvo service bulletin or software issue being addressed, I'd want that explained before spending $250–300 per car.
Also, keep in mind that the dealer/independent shop needs the appropriate Volvo diagnostic equipment and access to Volvo's software system for legitimate module programming. A cheap OBD cable or generic scanner generally isn't equivalent to an actual software download/programming session.
I develop software and automate processes. I help integrate applications using https://latenode.com/products/embedded-ipaas.
- 3939 Views
Last post by thudson
- 2875 Views
Last post by carboncow
- 2197 Views
Last post by blandis
- 4627 Views
Last post by phils94850
- 2343 Views
Last post by Almo77
