1999 V70R AWD prepurchase tips
benpineapple
Year and Model: '06 V50 T5, '13 XC90
Has thanked: 5 times
Been thanked: 4 times
Post by benpineapple »
Jazzop wrote:If it has Nivomat, I would switch to standard suspension as soon as it started acting up or if I were already doing work back there (e.g., replacing brakes or bushings). Is the Nivomat an option, or was it standard on the V70R? I've never dealt with it before.
Nivomat isn't exclusive to the V70Rs. I've seen a '98 V70R without the Nivomats. My V70 AWD (non-R) has Nivomat. There are a couple threads around for which non-Nivomat shocks/springs to get if you're doing a conversion. Also bear in mind, lower control-arm is different for Nivomat equipped models (at least on my 98), it all mounts differently up top as well as below.
Make sure the thing has a rear driveshaft. Runs on the PS next to the exhaust. Should be pretty obvious if it's missing.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
benpineapple
Just remembered, a great thing about the 99s is the service reminder light that comes one for the first minute of driving can be easily reset. On the 98s, it requires a special computer to reset. However, on the 99s do this:
-press and hold trip button
-insert key, turn to 2nd position
-when service reminder light starts flashing, stop holding trip button
Jellobmw
Year and Model: 1998 V70R
Post by Jellobmw »
Easy Peasy to deal with the service light on a 1998 V70R. Just remove the under desk cover and driver knee protection. Reach up inside, and remove the bulb.
