Seems like a crazy case of bad luck. (And who among us is worthy of such bad luck?) I would take apart the PCV again, piece by piece, and make sure there's no funny business in there. Maybe you did disconnect and connect something erroneously... I'm with polskamafia, I don't think a "clear" PCV could've caused this.
About the consumption of coolant. There quite a few reasons as to why that could have occurring, e.g., heater core, system burping, slow leaks here and there that only occur when driving, faulty reservoir cap, wrong coolant solution... Take everything apart again and double and triple check.
I'm hopeful. But I'm always hopeful! Good luck figuring this out.
1998 Volvo pcv question
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Retired:
2015 Volvo S60, T5, 85K
- Has thanked: 1611 times
- Been thanked: 4071 times
Independent failures. Figure out if it's oil from engine or ATF and then source accordingly.
JasonVolvoMan
- Year and Model: xc70 1998
Where is the oil cooler located
1998 xc70 170,000miles
1983 240 turbo one owner and 120,000 miles
Previous cars
1983 240dl 235,000 miles 5 speed. Should of never sold!!
1990.240dl 280,000 miles 5 speed. Should of never sold!!
2004 xc90 60,000 miles 3rd tranny
Previous cars
- Has thanked: 316 times
- Been thanked: 531 times
The oil cooler is on the left (passenger side) of the radiator. There are connections at the top and bottom that you will see.JasonVolvoMan wrote:Where is the oil cooler located
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
The headgasket and radiator are the only two places where coolant and oil can mix.polskamafia mjl wrote:...the oil cooler in the radiator...
- Has thanked: 17 times
- Been thanked: 35 times
Random failures that seem to be related but they're not- I've had them on my Volvo's....usually happen in threes not in pairs. It's just bad luck I think. In your case, I hope you can figure it out. On my son's 850 we had a transmission go bad because the radiator breached between the coolant and transmission fluid. In your case, I'm hoping it's your radiator and not your head gasket. It's a hassle but much cheaper and easier to deal with and at least you found it early...early enough that if that's what it is, your engine is probably okay- you'll just have to drain and fill with oil- maybe add something to clean up the breach... or do another oil change fairly early after things are cleared up.
- 30 Replies
- 9348 Views
Last post by Ben850
- 865 Views
Last post by aartzer
- 1659 Views
Last post by rspi
- 14 Replies
- 2101 Views
Last post by woodycaldercloggs
- 1492 Views
Last post by PatternFlyer
