There should not be any hoses terminating in "thin air".bugs11 wrote:Interesting. All the vacuum diagrams I looked at show that center (blue) line coming off the TCV ending in thin air. I plugged the hose into the nipple, see if it makes any difference. There is a skinny steel line running along the firewall but it terminates into the ABS pump.
Replacing all your hoses was smart, though - vacuum leaks on these cars from crumbling hoses is far and away what creates the most troublesome errors and symptoms with these cars - but still so easy to prevent.
I suppose you've been looking at something like this:
where it seems that the blue line ends in thin air, but if you look left, above where it says "Air filter", there's a note saying that the line should go "To fresh air hose". It's easy to overlook it - I certainly did the first times I was figuring out where all the hoses go.
- S
