DiCE not working when plugged into OBDII port Topic is solved
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
I can't get my genuine Volvo DiCE to work. If I plug it into a wall outlet, and test everything, the DiCE unit works just fine. If I plug it into the diagnostic port under the dash it doesn't do anything (no flashing or solid lights).
I really hope my DiCE isn't broken, since the warranty is up on it, and I don't want to spend another $650 for a replacement.
Has anyone had this problem and can help me get my Volvo DiCE working properly again? (I haven't yet, but I was thinking about unplugging the OBD cable from the main board and checking for power at the other end. Maybe the cable is bad?)
I plugged my generic OBDII scanner in to check the diagnostic port, and it gave me a cylinder 5 misfire code, plus let me clear the CEL, so I'm assuming the diagnostic port in the car is working the way it should be.
gnalan
Post by gnalan »
I took it apart, and checked the cable. All seemed fine. When I plugged everything back into the board I made sure I pushed each wire down, one at a time to fully seat them, before I put it all back together. I plugged it into the car and it was working again, thankfully.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Sounds like the connector was producing a high resistance on the V-bat or ground line. If it does it again clean the connectors.
Most likely tarnish and it does not take very much.
Active
Past
