Actually, that sounds like the oil trap.beigg wrote:Maybe we are misterming the part in question?
Bolts to radiator side of block in a vertical manner and feeds a spider web of vacuum lines, one to the top of engine and one to intake tube at compressor then a few other areas.
PCV post-replacement issues
- Has thanked: 311 times
- Been thanked: 817 times
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
The description was a bit vague. Either way, not a flame trap.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Have you done a compression test.
polskamafia mjl
I don't remember the intake hose being too difficult I think there is a hard to reach clamp on the turbo side but if you lean across the engine you should be able to see/feel it well enough.
polskamafia mjl
COuld be; do you have a boost gauge hooked up? That's the only reliable way to tell. More importantly, how is the oil leak situation?
polskamafia mjl
Do the glove test on the dipstick tube to see whether the PCV is working correctly or not. I don't remember whether you did the heater hose mod I mentioned in the beginning. That would be my next step.
- 1053 Views
Last post by sleddriver
- 11 Replies
- 2493 Views
Last post by Worrad
- 16 Replies
- 2742 Views
Last post by Cookeh
- 1848 Views
Last post by callahanoffroad
- 1518 Views
Last post by volvolugnut
