Did I trash my PTC valve
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
Thanks. No I didn't put another hole in it - was careful cleaning it out,and, like I said, it was totally blocked when I pulled it...... I think my PCV system is really clogged up.......
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Has thanked: 17 times
- Been thanked: 35 times
Your oil is probably from the PTC finally letting loose and everywhere oil can leak now it leaks. Yes, you need to service it or get it serviced. Hopefully you don't have any major seals leaking. I will say this though, when I first did mine I had a terrible leak and I thought it could be the rear main but it ended up being the rear cam seal (covered by the throttle position sensor- tps) and that one is not hard to deal with- in fact, it's the easiest of all seal leaks in my opinion!
azureblue
For now I pulled the dipstick out a little and the RMS leak almost stopped. A temporary band aid until I can get the parts, I doubt the RMS will stop leaking once the PCV system is fixed, but anything if better than it was.. Thanks
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
Theory question: What would happen if that hole was enlarged? That is, would it have the same effect as putting in a 5/8" hose from the PCV can?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Nothing would probably happen, as such - the chance of it clogging up again is probably lower, but then again, the whole thing has it's dimensions for a reason. I expect the heating might not work as well with a larger volume of throughput.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Has thanked: 311 times
- Been thanked: 817 times
In theory, widening the PTC hole should make a big diference. Everyone loves the fat hose PCV modification but really its only advantage in a stock setup is that it is cheap and easy. In theory, just adding a 5/8 hose actually does almost nothing to improve flow. The flow will always be limited by the size of the smallest orifice in that pathway, which is the PTC. Open the PTC, you have an opportunity to open the flow.
azureblue
that's what I thought, too - a larger hose won't make much of a difference if it still has to breathe through a small hole..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Sommerfeldt
That's true, but with the larger hose, you move the probable point of clogging to a far more manageable location, at least - it's easier to pull the intake hose or PTC and clean that, than dismantling the whole PCV system.azureblue wrote:that's what I thought, too - a larger hose won't make much of a difference if it still has to breathe through a small hole..
Remember also that the amount of flow in this system is pretty limited. In an otherwise healthy system, you won't need increased flow, you need free flow, which is what a larger hose will help achieve.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 1953 Views
Last post by precopster
- 1306 Views
Last post by 98v70xc206
- 3582 Views
Last post by southofmotown
- 14 Replies
- 2535 Views
- 994 Views
Last post by tmmike80
