96 R ABS module - again
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Re: 96 R ABS module - again
Post by Matty Moo »
No. You never soldered the other pins on the board and they crack too. Usually they will start before the two pins feeding the pump.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
Then rhat is what i will do after my vacation.?thanks for all the input.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
Post by sleddriver »
Years (decade+?) ago when I did this the first time, I examined all solder joints tied to the external connector pins with a very bright light & high-mag. goggles. Found numerous cracked solder joints. Found the same on my Dolby Pro-logic module, straight from the factory defective. I fixed it rather than return it!
Look at the solder joints from various angles to ensure there are no tiny dark lines (rings). Rather than just reheat the joint, remove all solder, check both hole & pad, and redo it with a hot, well-tinned iron.
I managed to fix the others, but the two motor pins...actually that ONE motor pin...on the left...was a stubborn hold out. Not any more. The ABS light has remained off ever since......thank God!
M1 10W-30 HM
Clemens
Post by Clemens »
So, as per matty moo's advice, i resoldered all the other joints as well. And the lights are gone. What remains though is an occasional rubbing sound and feel from the rear left brake. I put 4 new ate rotors and 8 new pads on the car like 3 months ago. So now that the abs module can be crossed of the possible culprit list, what could cause this pulsating rubbing? The pad/rotor mismatching (unlikely cuz both oem), a partially stuck caliper, the abs hydrualic block? Any advice qould be appreciated. Thanks
Summer: 1996 855 R
Donor: 1995 854 10V
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Clemens wrote:what could cause this pulsating rubbing? The pad/rotor mismatching (unlikely cuz both oem), a partially stuck caliper, the abs hydraulic block? Any advice would be appreciated. Thanks
I had one of the rear pads get stuck on the caliper. I just pulled it all apart and used a wire brush attachment on a Dremel tool to clean all of the rust off and never had any more problems.
Has thanked: 1850 times
Been thanked: 1712 times
Rear calipers tend to get sticky over the years as they work less hard. Lee has made an excellent suggestion of cleaning all the contact faces to ensure the pads can move smoothly without binding. Have someone gently press the brake peddle with the pads removed (one caliper at a time disassembled) to make sure the piston is moving smoothly. Check there are no cracks in the piston boots and they are not rusty.
Have you done any service work on the rear parking brakes? These are not a fit and forget item most folk think they are. Pull the rear rotors and check the shoes have not delaminated and again have someone gently pull on the lever and check the cables move easily and are not binding.
Have you ever replaced the flexible brake hoses? Again these can collapse internally and prevent the calipers releasing as they should.
Good luck!
Clemens
Post by Clemens »
So last night i took the left rear brake apart. The parking brake assembly looks good (i adjuated them a whe ago, but better safe than sorry) but the inner piston was stuck so i got it moving again. Since i didn't take the caliper off the car i couldn't really rebuild it, i just broke it loose by locking the outer piston and then pumped the pedal a few times. Might be a temporary fix only. Now the left side seems to work alright again, but i will also di the right reat one as the rubbing still can be felt. Interesting input about the rubber line collapsing. I just had the front ones replaced but will do the rear ones soon as well.
Summer: 1996 855 R
Donor: 1995 854 10V
jking4020
Year and Model: 1997 850, 2001 v70xc
Been thanked: 3 times
Post by jking4020 »
I also have abs issues. Checked circuit board and was fine. I still installed a replacement abs unit but no change. Speedo will go out any time. Front brakes hum on long stops. And I have to hit my horn to get shifter to move and most electronics to work. Back brakes barley seem to work if at all. It's a 97 850 turbo.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
jking4020 wrote:I also have abs issues. Checked circuit board and was fine. I still installed a replacement abs unit but no change. Speedo will go out any time. Front brakes hum on long stops. And I have to hit my horn to get shifter to move and most electronics to work. Back brakes barley seem to work if at all. It's a 97 850 turbo.
Sounds suspiciously like a bad ignition switch.
The contacts wear out and all kinds of things happens.
It's a really simple swap, though. Budget about 50 bucks
and stick with OEM for the new electrical contact block.
Has thanked: 1505 times
Been thanked: 3818 times
Clemens wrote:So last night i took the left rear brake apart. The parking brake assembly looks good (i adjuated them a whe ago, but better safe than sorry) but the inner piston was stuck so i got it moving again. Since i didn't take the caliper off the car i couldn't really rebuild it, i just broke it loose by locking the outer piston and then pumped the pedal a few times. Might be a temporary fix only. Now the left side seems to work alright again, but i will also di the right reat one as the rubbing still can be felt. Interesting input about the rubber line collapsing. I just had the front ones replaced but will do the rear ones soon as well.
Yeah, that's going to lock up on you again. It might help to flush your brake fluid out and put in fresh, which you should do every two years anyhow, but the corrosion damage is probably already done.
The rear calipers on my 1999 are non-floating type ( caliper stays still, two Pistons move) which last longer but have to be replaced when they freeze. I found the FCP Cardone after markets to be rebuilt OEM ATE calipers at 1/4 the price.
