So i boighz my R with abs and tracs light on. Cut the module open, found the main power supply solder joint cracked, soldered it and sealed evrrything with a rubber sealer for electronics.
Lights never came on till today. Now i have a permanent abs and tracs light right after startup. Where do i start looking for a mistake? Also, i need to mention that a?few weeks ago i had abs action on the front left or rear left wheel when braking hard and turning at the same time. Checked all wired and abs rings and they seemed alright. But of it were a sensor or a ring it would most likely not?illumnate the abs and tracs right after startup but after moving, right. Any ideas are welcome.
96 R ABS module - again
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 12 times
Same experience here. My repair would last for a year or so, then fail to the pump motor connectors. The last time it happened, I looked very closely at the failed joint and noticed that the solder joint failed right at the pad. Barely a mm in distance. So I sucked off the solder and noticed a very tiny pad...too small in my opinion, for such a large dia. pin/lead.
My solution was to remove additional material around the motor pins, exposing the copper layer underneath. Next I tinned this surface, before resoldering the joint. This provides a MUCH better connection to the circuit board that will withstand the vibration.
- Next I wiped it down with ethanol, tinned the bare copper board, then resoldered both joints, forming a pyramid with a much wider base compared to before.
The final step (not shown here) is to remove the solder flux using ethanol to clean up the joint. - ABS Module 010.JPG (182.53 KiB) Viewed 2166 times
M1 10W-30 HM
M1 10W-30 HM
- Has thanked: 1506 times
- Been thanked: 3820 times
Thats too much heat on that board. You need to be in good practice to pull this repair off.
- sleddriver
I didn't overheat the board. The grey marks are not burn marks from a torch or flame.
What might look like it to you is actually from the small wire brush used in a Moto-Tool. It wasn't up to the job of removing the etch resist, thus I had to manually scrape it off.
M1 10W-30 HM
M1 10W-30 HM
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
This is very interesting. Did you feel any strange behaviour from the pump or did just the lights come on?
@ moderators: i must have started two thredas accidentally. Sorry about that. Can you merge them?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
- sleddriver
I'm trying to remember when my ABS ever has engaged...in the 18yrs I've owned the car. No ice where I live, just heat & humidity. The brakes aren't touchy. It won't even skid, save for loose gravel.
Main code was "pump motor faulty".
M1 10W-30 HM
M1 10W-30 HM
Teddy1975
- Year and Model: 2007 V50
- Has thanked: 1 time
- Been thanked: 7 times
Don't need icy conditions for ABS to engage. Slam on the brakes so hard it locks up the wheels. ABS will/should kick in... But wait until there's noone behind you
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
- sleddriver
ABS will only activate when the controller detects skidding. I've tried a panic stop from about 30mph. What happened was an immediate ALL STOP. No skidding at all. Write it off to new rubber!
I'm one of those who tries to swerve to avoid a potential collision, rather just slam on the brakes & pray. I've only lightly tapped a vehicle in front once...in 40 yrs of driving.
M1 10W-30 HM
M1 10W-30 HM
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
It activates when it senses a given differential in wheel RPM's.
Hit'em on gravel. If it's working, you'll know!
- Clemens
Another thought on my issue: could it be the hydraulic block where the brake lines go to? How could that be diagnosed for sure.
Summer: 1996 855 R
Donor: 1995 854 10V
Donor: 1995 854 10V
