So i boighz my R with abs and tracs light on. Cut the module open, found the main power supply solder joint cracked, soldered it and sealed evrrything with a rubber sealer for electronics.
Lights never came on till today. Now i have a permanent abs and tracs light right after startup. Where do i start looking for a mistake? Also, i need to mention that a?few weeks ago i had abs action on the front left or rear left wheel when braking hard and turning at the same time. Checked all wired and abs rings and they seemed alright. But of it were a sensor or a ring it would most likely not?illumnate the abs and tracs right after startup but after moving, right. Any ideas are welcome.
96 R ABS module - again
jimmy57
- Been thanked: 320 times
Open it again and solder every pin to the PCB on that end of board.
The lamp is lit for every fault. The common ones are power supply/pump faults and wheel speed circuits.
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
You can't just resolder one joint, you have to do all of them.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
Thanks, Matty, I wasn t aware of that. I thought looking for one broken solder joint is the way to do it. So I will resolder all connections and hope that does the trick. I'd send it out to you, but s&h back and forth is a small fortune.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
