the big rubber bushing that the prop shaft goes through. it has two bolts and bolts of the exhaust hanger in the middle of the car.
the bearing is different between the two prop shafts I have but the end caps are the same and so is the length of the shafts.
1998 v70r driveline swap into a 2000 v70 xcse?
mrjacobrussell
- Year and Model: 2006 s60R
- Has thanked: 2 times
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
2005 v50 t5 AWD for sale
I have a Chinese DICE, works well.
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
- Has thanked: 2197 times
- Been thanked: 1850 times
Does the 98 support bracket bolt holes for the bolts to the floor pan line up with the holes for the 2000? If so you should be able to swap the whole item over, if as you say the 2 ends of the earlier prop-shaft fit with the 2000.
