Thanks all for the replies.
I thought the Autel MS300 would work on a 2006 XC70, but if there is one thing I know, it's that I do not know everything. I appreciate chief_bottlewasher confirming that it won't work on my car.
I took a look at the DICE readers as VTL suggested, but that would require me to purchase a Windows based computer. I, like abscate, do not wish to own a Windows computer. The cost involved of purchasing the DICE and the computer was also a deterrent.
I then looked at the Autel MD802 since two of you mentioned it was a good reader. I like all the features it has. After much debate between the Autel MD802 and the iCarsoft i906 I looked at earlier, I decided to go with the iCarsoft i906. The Autel MD802 has more features than the iCarsoft i906, but after just purchasing my XC70 and having to change the alternator, MAF, and AC compressor (I knew the car needed all these repairs before purchasing), money is a bit tight. So I went with the iCarsoft i906 because it was $115 less expensive.
The iCarsoft i906 arrived today. I plugged it in and it reset the check engine light after replacing the MAF to resolve the P0243 code. I was also able to reset the SRS light (which I had inadvertently set off by pulling a fuse).
Thanks to everyone for the suggestions as this conversation is what led me to purchase my new scanner. I appreciate it!
Scan Tool Code Reader Suggestions? Topic is solved
combatkarl
- Year and Model: 1997 850 GLT
I have the Autel 619 purchased from Amazon. After my son completed the software upgrade on a Windows PC, it worked on my '97 850. It has also worked on the Mazda Miata & Ford F-150. It will do SRS, ABS, and check engine lights. I doesn't not cover the ECC in the Volvo 850
which I think the Autel 800 series would, but was ~$100 less expensive.
Karl
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
1984 Honda Nighthawk S bike
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
- Has thanked: 2865 times
- Been thanked: 1332 times
Links to these code scanners at Amazon in case you want to buy one and help out MVS.
iCarsoft i906
Autel AL619
iCarsoft i906
Autel AL619
ThommyKent
- Year and Model: 91 245 97 850 T5
- Been thanked: 5 times
That`s for sure!abscate wrote:A lot of us have no interest in ever owning a Windows computer, ever again.
ThommyKent
The iCarsoft 906 is excellent!matthew1 wrote:Links to these code scanners at Amazon in case you want to buy one and help out MVS.
iCarsoft i906
Autel AL619
- 20 Replies
- 4851 Views
Last post by smacknab
- 14 Replies
- 11474 Views
Last post by North42g
- 3769 Views
- 3326 Views
Last post by rusty volvo
- 2588 Views
Last post by JudgeRat
