PNP woes
- Z06killinsbf
- Year and Model: 1998 V70 T5
Yes doing all of that, I'll check that out once I get back home. Thanks!
1998 V70 T5
- Z06killinsbf
I can't find any loose connections or anything unplugged. So digging around online I found a PNP wiring diagram, looks like there are possibly some inline fuses going to the connector so I guess I'll plug around the fuse box. If I can't figure this out soon a big red for sale sign is going up in the window!
1998 V70 T5
- Z06killinsbf
The thing that kicks me is that I can rotate the PNP from max to max adjustment and there is no loss of reverse lights like I see everyone dealing with. I even put the trans in neutral and rotated it thinking I may come into range but the lights never came on. I can sit there all day and rotate the switch back and forth all I want and the lights stay on as long as it's in gear, weird.
1998 V70 T5
- Z06killinsbf
https://www.amazon.com/gp/product/B001L ... B001LHVOVK
Will this scanner read transmission codes? I've used a guy I know across town who has one but would like to have my own. My scanner wont read trans codes.
1998 V70 T5
- Has thanked: 316 times
- Been thanked: 531 times
That won't work. You'll need something like Vol-FCR and a VAG-COM KKL cable. Little info on this thread here: https://www.matthewsvolvosite.com/forums ... =1&t=68710Z06killinsbf wrote:https://www.amazon.com/gp/product/B001L ... B001LHVOVK
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
So you've got the PNP switch plugged in and the key in position 2; you're saying no matter which way the center shaft is turned inside of the PNP switch your reverse lights are always on? Where is the shifter set to?Z06killinsbf wrote:The thing that kicks me is that I can rotate the PNP from max to max adjustment and there is no loss of reverse lights like I see everyone dealing with. I even put the trans in neutral and rotated it thinking I may come into range but the lights never came on. I can sit there all day and rotate the switch back and forth all I want and the lights stay on as long as it's in gear, weird.
You mentioned this isn't a Volvo part but I don't think you said who made it. I think sometimes our faith in Volvo parts may be misplaced but for electrical components staying OEM is worth it.
I know how frustrating this can be as I had to deal with a similar issue last Spring. It would be best if you could pull the transmission codes but without towing it to a dealer that will prove difficult.
- Z06killinsbf
polskamafia mjl wrote:So you've got the PNP switch plugged in and the key in position 2; you're saying no matter which way the center shaft is turned inside of the PNP switch your reverse lights are always on? Where is the shifter set to?Z06killinsbf wrote:The thing that kicks me is that I can rotate the PNP from max to max adjustment and there is no loss of reverse lights like I see everyone dealing with. I even put the trans in neutral and rotated it thinking I may come into range but the lights never came on. I can sit there all day and rotate the switch back and forth all I want and the lights stay on as long as it's in gear, weird.
Shifter in reverse or neutral I believe. I can manually shift the trans itself using a wrench and once it clicks into reverse it lights the lights.
I'm not sure, I picked it up off of Rockauto.
1998 V70 T5
- 57gretsch
- Year and Model: 2005 XC90 T6
- Been thanked: 2 times
I had bent a pin while reconnecting the wiring harness.
When revisited the pnp...I noticed the bent pin. Fixed that. All was good since.
No good deed ever goes unpunished.
1997 855 T5, 2000 V70XC, 1998 V70 AWD Manual, 2007 XC70
- Z06killinsbf
Does anyone have a copy of Vol-frc software? I'm wary of downloading an from an unknown source. I just ordered the cable listed above. Thanks everyone
1998 V70 T5
- 801 Views
Last post by polskamafia mjl
- 1183 Views
Last post by anbran1
- 1006 Views
Last post by DEWFPO
- 560 Views
Last post by draser
- 1137 Views
Last post by techedbob
