1993 volvo 240
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Skymaster wrote:Temperature gauge goes into the red.
Engine Says: But don't play with me, cause you're playing with fire
AC fan delivers a gentle (aka light) breeze, if AC-condensor and radiator is not blocked, only a light breeze goes over radiator.
OEM fan clutch will provide enough air flow, if cowing is there, and AC-condensor/radiator is not filled with bugs/etc.
I would get a thermal sensing gun and see what temp is at thermostat housing. When Volvo's gauge is in the red, shit is about to hit the fan. Your engine may die at a idle if too hot...pistons will be dragging on cylinder wall.
There are different ways to wire it...forget the diode...with your setup, you know AC fan is working...just shied those wires.
