Replacing rear carpet panels with wood?
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
plumsmooth wrote:HI There proud Volvo enthusiasts. Has anyone thought of or actually replaced rear carpet panels with something other than junkyard replacements...
Yep. A single piece of nice carpet remnant. Original rear carpeting still looks new...19yrs later. I didn't want mine looking like yours!
A wagon is versatile, but a truck it's not as the useful load is about 950#'s....including the driver. I discovered this when hauling asphalt roofing shingles that weigh 85#'s/bundle. I could only carry about eight at a time. Seeing how I needed about 70 to do my own roof, that's a lot of trips...and wasted time. So I borrowed a mid-90's Ford F150.
Forget about it being a large gravel hauler: See above.
I'd suggest contractor-grade clean-up bags. They're less likely to leak!
M1 10W-30 HM
plumsmooth
Year and Model: V70 Wagon 2004
Post by plumsmooth »
You guys can project all of your Romanticized versions of Volvo Wagon reality you want to on me...
But the realty is that it 'is' my "Truck" and I am proud of it...
I got no one to impress definitely not you guys so take a hike...
There's plenty of parts of the world where villages/villagers would be more than happy to put this Truck though every rigor and farming task known and possible to help feed their Families!
I think my 850 Wagon (which does have a soul) is proud to be a Truck!
When I pick you up hitchhiking I will clean the garbage juice for you so you have a clean place to sleep with the back seats down...
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I like to treat my wagon nice, but the utility aspect is one of the best parts of having a wagon. You have a nice DD while having a "truck" at the same time. An actual truck would be nice at times, and of course for dirtier stuff, but my wagon works great for more basic things. I've hauled a couple hundred pounds of dirt (bagged and on a tarp, of course) in my wagon no problem. I love it!
sleddriver
Dude, the REALITY is that the wagon has a max. useful load limit.....before you PERMANENTLY sag/shorten the rear springs and bend the rear suspension. Then your wagon will trot down the road with its butt out to one side and your tires will wear funny.
We're not impressed......no worries there.
Why don't you build a box out of 2x4's and CDX ply if you want to haul?
Gravity: It's Not Just a Good Idea. It's The LAW!
M1 10W-30 HM
bmdubya1198
Not like I was hauling it cross country. Yes, the car does have a load limit, which I had not exceeded. I'm not an idiot.
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
I too have hauled stuff in the wagon- have the plastic base thing and another vinyl thing like this one- have thought of replacing wood or covering it wiht aluminium
98v70dad
Year and Model: 98 V70
Has thanked: 1 time
Post by 98v70dad »
weathertech cargo liner will cover the nasties you already have and hold any liquid that you spill since it has a lip all around. Get a used one - they're cheaper.
s10lowrider1994
Year and Model: 2000 v70
Been thanked: 3 times
Post by s10lowrider1994 »
I'd be tempted to take every panel out and have it done with line x
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I often had 140KGs/300lbs PLUS in the rear of my 2000 wagon and it took it like a champ. Yes the rear springs are probably a little lower than the factory intended and I don't have NINO-MATS :P The luggage boards are steel reinforced with box tube. Try doing that in a Camry or Mazda.
I stayed off freeways when lugging weights as I didn't want printers breaking through the rear seat area if anything happened. I now have a VW diesel Transporter with cage for the heavy stuff.
Front bumper only stayed on because of a single zip-tie after a hit and run.
This is how my wagon ended up tonight on her last night of ownership. She was worked hard as an A3 printer carrier for 5 years and almost 100,000kms in my ownership. Her last odometer was 352,000kms with only one breakdown due to a failed regulator. Recently she carried back the entire engine/transmission assembly for my 2001 XC70 and there was some oil/grime spillage. The carpets and boards were already torn up by the printers.
My family rarely rode in her except for morning school drop offs as the A/C never worked. I'm going to miss that reliable engine that still has original MAF and engine mounts (sagging now)
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Post by shaker_chi »
Pull everything out and powerwash EVERYTHING. The day before you do that pre treat the whole thing with spray on oxi-clean. It is going to take a while to clean all that out so be patient. If you have a power washer at home, connect it to your washing machine hot water supply. Once it dries, go to Sam's or Costco and buy 2 of their large entrance mats. One should cover the back portion and the 2nd will cover the back of the seats when you lay them down.
