Absolutely. Nice work you have found a demon. Be careful replacing the injector relay, the connector on that one is a known weak spot. It sounds like yours the issue is the relay, not the connector, but inspect it carefully when you go in there.
The ECT might be contributing to the hard start or might not. I can;t see the fuel injector relay making the fan run but not sure. You could wait on that one to see what happens after you sort out the fuel relay, but if it has never been replaced, now might be a good time. The ECT also has a fragile connector, be careful! And it really needs to be the factory brand, don't buy a cheap aftermarket ECT.
94 850 - Random Stalls and Hard to Start Topic is solved
- Has thanked: 311 times
- Been thanked: 817 times
jjs70pdx
- Year and Model: 2000 Volvo S70 AWD
Just confirming I've been driving my car three weeks without any further issues since replacing the fuel injector relay. I haven't had the cooling fan come on since then so I am waiting on replacing the ECT.
- 1018 Views
Last post by OffsetBuffalo
- 5549 Views
Last post by SwissXC90
- 41 Replies
- 7196 Views
Last post by eriscentro
- 605 Views
Last post by wizechatmgr
- 33 Replies
- 1950 Views
Last post by misha
