I have no direct experience with a PO422, but I did have a PO420 on another car, and had to pay for diagnostics as part of Ontario's DriveClean. The tech that did the diagnostics used an infrared thermometer to measure the temperature of the exhaust before and after the cat. It was the same, indicating that the cat wasn't lighting up and burning off emissions. It should be ~200 deg hotter after the cat. Alternatively, you can look at the waveforms from the front and rear O2 sensors. If the rear sensor swings with a similar pattern to the front sensor, then the cat isn't doing its job.
If your diagnostics point to a new cat, you can have a Magnaflow cat welded in for about $250 parts and labor-- I have used L & G in Markham and have been very happy with their work.
98 S70 - Keyfob Programing, po133 lambda, Door Check Dizaster. Topic is solved
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
What is my best coarse of action to fix the Sunroof? buying the 150$ ebay ones? or finding a 500$ parts car with a good one and take it off that.
The heater core i still didnt change since it seems to be just a slight drip at the o rings on the original heater core, i should do it soon but im guessing The o rings came with the Swedish auto parts heater core are not genuine?
With your po422 thing, i have same no bad smell and no difference in performance still drives very nice. But Talking about rear sensors... I use a cable through my laptop for the Scanmaster elm program. and i notice im not getting any voltage to the 2nd sensor. So is that the culprit??? if so that sucks because I bought a Brand new o2 sensor from Bosch 2 months ago and i remember when i was getting the po133 code for the manifold not seeing voltage to the sensor then either, Basically am i supposed to see a voltage going to the 2nd sensor from that software aswell? Now you got me wondering if that sensor is bad. and yes po422 is the only code i have, it seems to come on after 150km of driving. The o2 spacer is cheap, but im wondering if i have to make sure theres a voltage going to the sensor first. I could upload a screenshot of my computer running the software with the car connected if that helps. Is there a better goto software people are using now? i always thought scanmaster 2.1 elm was the best maybe not anymore?
I was at highway speed today and I swear when it came on, i almost felt a slight change in the pedal and boom light came on again maybe that was just going into the richer mode or something i dont really know too much about that..
Thanks again guys. Even with all the little issues I still love the volvos, maybe im crazy!
P.S Still have that crappy door stop welding from the picture above to deal with, nobody wants to touch it it seems. Would love a referal to someone in the GTA who wont charge a fortune.
97 850 GLT platinum edition 225km - RIP Headon accident
97 850 wagon non turbo SE 570km - RIP. No ac, still runs, but started using as a Parts car
98 S70 non turbo SE 237km - Daily Driver Runs nice, but po422 nightmare.
- 868 Views
Last post by packetfire
- 1636 Views
Last post by nico416
- 769 Views
Last post by Ozark Lee
- 1441 Views
Last post by mf70
- 1874 Views
Last post by eyerollXC70
