The Magnetti Marelli ETM. Which cars have it?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
See this viewtopic.php?t=80237lavellp7 wrote: 12 Apr 2019, 19:03 how do sergey or henry load update software to virgin etm??????????????
precopster
- Year and Model: Lots
- Been thanked: 128 times
Missed your post. XeModex do great work but postage is the limiter. IPD stock XeModex throttles as I said. If you want to use a white label to send to XeModex it makes no difference; XeModex address all the inherent weaknesses whether white or yellow label.
Volvo's rebuilt units can be as early build as 1999 and I don't know what exactly they do to the throttles apart from the contactless conversion as it's a "trade secret"
Those guys use your Dice and their special connection software.
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
Just for additional info:
ETM Magnetti Marelli also were installed on bifuel engines B5244SG (S60/V70/S80 2000 - 2007)
Volvo electronic expert
Online Data Transferring Service for Volvo modules
Enjoyed all the comments. I have a 2002 V70 Base and the Magneti Marelli number is 8644345 65CFM9. I am not sure which number is the most important. I think the 8644345.. My issue is finding one? There are many that are a digit off: 864436 or 8644347 Do I need an exact match? Some say to check the vin number and if the 5th and 6th are 61 then it should be compatable??
Thanks
John
Thanks
John
precopster
The current replacement part number for your throttle is 36050564
Many parts suppliers say they are supplied unprogrammed however in my experience all were supplied ready to go
precopster
For a 2002 non turbo the ONLY throttle from Volvo factory that has a chance of a sw match is the one I provided unless you buy a used one from a 2002 non turbo.
VIN may have a bearing. More important is engine type and year. John your car has a B5244S which is also shared with 2000 and 2001 MYs however Volvo had a sw update for the 2002 MY for the ETM.
And yes I agree sw numbers are the most important thing however without Dice diagnostic that is a pointless discussion.
- Has thanked: 1614 times
- Been thanked: 4078 times
- 9709 Views
Last post by John65
- 4324 Views
Last post by vtl
- 16904 Views
Last post by Xxjoshiexx
- 2327 Views
- 2686 Views
Last post by volvolugnut
