Volvo 850 Jumping starter with cooling fan out
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
Or could I just measure resistance between that plug and the green wire on the solenoid terminal?
Has thanked: 1610 times
Been thanked: 4070 times
Just looked at a 1997 today. The starter connection is like the 99 above
JimBee
Post by JimBee »
My 93 and 96 850's don't have that.
Lee's post that you linked describes what mine looks like. I'll test it top-side connector to starter green wire terminal to confirm. We'll get to the bottom of it!
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
That is indeed the correct connector.
Yes ! Jim.
Key off.
VOM on ohm mode. Check for O ohms between the strut wire and the green/red connector that attaches to the starter solenoid. You want the wire itself, pulled off the solenoid .
JimBee
Post by JimBee »
Got it. It's looking like Monday when the vortex lifts before I dive into that.
Just for additional clarity: even with the key in position I or II, there shouldn't be volts in that wire, right? Though presumably with key turned to start (position III) it would read 12 volts. Right?
With this thread cleaned up we should have a clear explanation of whether an 850 has that starter jumper and, if so, what it looks like: 93 does not seem to have one, 94?, 95? not sure; 96 does have it as per picture and Lee's confirmation + my test; and looks like it was further changed in 97 on.
Jim
Post by Ozark Lee »
Only with the key in position III.
