will my tuned ECU/turbo from my 98 v70awd swap in to a v70r?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
tryingbe wrote:Whatever helps him to sell his retune.
:lol:
Either way, the base tune is no longer there, so it's not treating it as a stock GLT and it should run fine if he's using the same injectors, turbo, etc. Although, the tune is still made for a 2.4 engine, while the other car is a 2.3. The tune will probably be off, but it should still work. Kinda like running a T5 on a GLT ECU (perhaps less extreme than that)... it'll work, just not the best. I don't know how much a tune will differ as far as compression and displacement goes, but it is worth mentioning that T5 ECUs are commonly used on LPTs along with a 15g/16t and blue/white injectors with good results.
broken08 wrote:ARD replied and said it will all swap right in but for best performance a retune would be good.
And to the grump who said I shouldn't have tuned the LPT...quit being a grump. ARD also noted the LPT is capable of more power than the R after tuning, so....yea
Agreed on tuning LPTs. They have much more potential than factory HPTs depending on how they're modified.
