1999 V70 XC AWD Turbo 2.4 - Blowoff valve diaphragm defective Topic is solved
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
No worse than a VW! Haha
Definitely replace the PCV parts. That hose shouldn't be broken.
Has thanked: 1609 times
Been thanked: 4065 times
Sorry - should have posted back on this one
Okay - there are a couple of diagrams in the VRD, but the short version is
One gets pressure from the turbo itself (to drive the waste gate valve - I don't think that should hold vacuum -when the engine is off that hose waits for boost from the turbo
One hose routes the boost pressure to the waste gate - that one should hold vacuum.
One hose dumps un used boost pressure back to the air duct, pre-turbo. That one will not hold vacuum.
Why don't you pop up to me and swap out my known good 99 TCV and see if it helps your boost one weekend??
