Ah, Thanks! My cruise control worked the last time I used it and I speculated I must have knocked that loose with looking at the leak at the purge valve. So it must haven't had anything to do with the stall and was just caused by me knocking it off.jimmy57 wrote: 24 May 2017, 11:04 The thing bellow batt is the ruise control vac pump/regulator and has a vent port open on purpose.
'96 Stall coming to a stop then no start Topic is solved
magna224
- Year and Model: 850 T5's
- Been thanked: 4 times
Volvo 855 T5 1995
Volvo 854 T5 1996
Toyota MR2 1987
Volvo 854 T5 1996
Toyota MR2 1987
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
The vent hose that was disconnected near the subframe is an emission hose from the purge valve going back to the fuel tank.
magna224
That's what I thought but I couldn't remember where I followed it to. My EVAP theory led me to two major leaks. The cruise control was most likely my doing while inspecting the purge valve because like i said it worked before. I think these major leaks caused the original stall. This makes sense right? The pump and MAF should be here today or tomorrow. Maybe it was a bit of two problems. A slowly failing fuel pump and these major leaks that probably happened when I filled the tank to full. Like I said I had been suspicious of a small fuel issue now going on 8 months or so. Maybe it was just this EVAP issue along side a dying pump.rspi wrote: 24 May 2017, 15:43 The vent hose that was disconnected near the subframe is an emission hose from the purge valve going back to the fuel tank.
Volvo 855 T5 1995
Volvo 854 T5 1996
Toyota MR2 1987
Volvo 854 T5 1996
Toyota MR2 1987
- rspi
Contact rspi..
That evap leak did not cause the car to stall.
magna224
Fuel pump was making noise and starting the car but dead as you all expected. Now lets see how long this hella pump lasts. I popped one disconnect off with a prybar the other I used screw drivers. The install of the non standard pump felt odd everything just was off a bit but it seems to work great so far after only a few short drives.
Volvo 855 T5 1995
Volvo 854 T5 1996
Toyota MR2 1987
Volvo 854 T5 1996
Toyota MR2 1987
- 735 Views
Last post by misha
- 58 Replies
- 11054 Views
Last post by precopster
- 14 Replies
- 2419 Views
Last post by br0dy519
- 3515 Views
Last post by 93ForMe
- 1713 Views
Last post by TheCynicalCanuck
