1999 v70T5M oil seep at rear (right side) of engine 3514546 30637866 (turbo return line) Topic is solved
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Re: 1999 v70T5M oil seep at rear (right side) of engine (turbo return line)
Post by tryingbe »
You're welcome.
I moved away from Volvo as 2 people doesn't' need a wagon.
My current car get this for MPG, if I hypermile it.
85 GLH, 367 whp
00 Insight, 72 mpg
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Just looking at the before and after and thinking I may just replace that seal. I also removed the timing belt upper cover and saw everything is reasonably dry.
Obviously the AWD angle gear will make things fun, but I believe this should be a decent job for me to do. Far easier than removing the ghost damper of hell bolt.
Has thanked: 1497 times
Been thanked: 3809 times
Gasket, two new hex screws, o ring. Under 15 bucks all in?
Spray the M6 clamp well a week before planned
Part numbers
Oil drain line flat gasket 3514546
Oil line o-ring into engine block just above pan screws 30637866
