Turbo oil return line 96 850.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
I'll be replacing the gasket and o ring as they are leaking. Anything else I should do while I am in there? What about the oil thermostat gasket, for example. There may be oil leaks from elsewhere on further looking, but I'd happily accept advise about what specifics I should be looking for, thanks.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
You'll have to drain the coolant so you can unbolt the coolant pipe at the turbo towards the rear of the car first before you can remove the turbo oil return tube. Be sure to install the gasket dry with NO RTV.
85 GLH, 367 whp
00 Insight, 72 mpg
rguzz
Post by rguzz »
Thanks, saw robertdiy's video on this job. Looks pretty simple. Not sure why coolant line needs loosened, but if I didn't I suspect I'd find out the fit is too tight to remove oil drain line. But what else do I look at while I'm there?
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
I would just clean up the loose oil and verify that nothing else is leaking up there.
Klaus
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I never pull that line on the fwd cars, but that would not hurt, make it a little easier.
rguzz
Post by rguzz »
I think I might try without, and if need be I will. Draining coolant is always a PIA.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I did this job not too long ago on both 850 and S70. On one of the cars I had to slightly loosen the coolant hose, the other car I didn't.
Neither did I drain the coolant. Things to do: put anti-sieze on bolts and lubricate the seals with oil before installing. I posted something to this effect.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
rspi
Post by rspi »
I just had to pull the turbo on a '98 V70 awd to do it because someone had stripped one of the bolts and did not use the proper seal on the block side. Some people's kids.
