99 S70 Turbo won't start
double_eagle20
Year and Model: S70 1998, S70 1999
Re: 99 S70 Turbo won't start
Post by double_eagle20 »
Does anyone have any comments on the slow rotation when I try to start it? I tried with two different batteries and got the same slow turnover.
Junior is not here right now to answer questions, but my understanding is that car quit and then overheated. I concluded that it overheated because of a low/dead battery that was unable to operate the fan. I could be totally full of crap on this reasoning.
Thanks.
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
Post by sleddriver »
double_eagle20 wrote: 23 Jun 2017, 08:42 Thank you shegarty. I had assumed that the coolant dumped out of the overflow due to the car overheating due to the fan not working due to the low battery. But your comments and the previous comment have me worried about the belt jumping or breaking.
Not so fast....the rad. fan could have quit due to a faulty bullet connector or fan relay...not a low battery.
Start with the simple stuff first
M1 10W-30 HM
double_eagle20
Wellll, I don't know if this is the simple stuff. I finally got back to this vehicle after fixing two others. Pulled the timing belt cover to discover the water pump frozen and the belt off the pulleys. Any and all advice is welcome at this time. What do I have to look for? How do I check for damage to the valves/pistons? What is the best way to fix this? Or is it junk?
(Note that I have done several timing belt replacements on S70s so don't need too much direction there.)
Thanks!
double_eagle20
Another question. Assuming that I go ahead and repair this, what brand/source should I be looking at for a new water pump and timing belt?
Thanks.
Has thanked: 1497 times
Been thanked: 3810 times
I think there is a water pump brand thread discussion in the Parts forum. Aisin or HePu are the brands frequently discussed here.
RigsPGT
Year and Model: Red 99 S70 T5,
Been thanked: 2 times
Post by RigsPGT »
Install a new pump, belt kit and give it a try. Make sure to time it correctly by using a cam locking tool. Don't rely on cam marks only (ask me why). I was advancing mine 15-20 times because the cam gears were dialed in such way that even though I was spot on, in reality I wasn't.
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
double_eagle20
Ok. I will go ahead with a new pump and belt kit. It may take me several days to get parts and get the job done. I will report back here with the results.
Thanks.
On reflection, a used pump and timing belt would be useful to evaluate if the valve train is trashed so that you could make a cost free diagnosis rather than have to buy new parts, especially if bent valves mean end of life.
Does anyone have old parts from a tB and water pump job?
double_eagle20
The failed pump is from NAPA. They have a lifetime guarantee. So, I can get a new pump that way and probably have a used belt I can use to test things out. I don't intend to use the Napa pump long term because this is the third Napa pump failure I've had in the last 2 years. I'm still pretty busy with other stuff so might not get back to this car for a few days. But I will report back with results when I get farther along.
Thanks.
double_eagle20
Hello again after all these months. I let the car sit for the last 6 months and finally got back to working on it. I replaced the water pump and timing belt. The car starts and runs now. I have not driven it yet. Just idled it in the garage and revved it up a little bit. All of that seems fine. BUT, there is a lot of "lifter" type noise. Could this be bent valves? Could it be an artifact of having sat for 6 months? How can I figure out what is going on.
Thanks.
